I bought this APU build with the 5600g two months ago in hopes of getting a GPU soon but that's not gonna happen now. I want to overclock the iGPU but I know absolutely nothing about overclocking. What exactly do I do?
Here are my specs: Ryzen 5 5600g, 2x8 3200 MHZ Crucial green RAM, Gigabyte b550 DS3H.
Thanks in advance!
https://linustechtips.com/topic/1425796-need-a-guide-to-overclocking/
Not sure you can get much out of a 5600G, but look here for OC guides : https://skatterbencher.com/
Igp just crank the gpu volt to 1.3-1.4 for freq of 2300-2400
Rams is where it gets interesting, what rams are you running? And check thaiphoon burner for what ram ics you have, for decent ics hynix cjr/djr can do 4400+ cl19, micron rev b/e can do 4500+ cl18, and trash b die im not sure but you wanna crank volt to 1.6-1.7v for trash b die as that helps with ocing due to b die scaling well with volt
