the only difference i can think of is
3570k is unlocked (overclockable)
3570 is locked (cannot overclock)
3570 is partially locked (can overclock to a small extend +x4 Mutliplier)
edit:
base up to 3.8Ghz
Turbo on 4 cores -> 3.9 Ghz
Turbo on 3 cores -> 4.0 Ghz
Turbo on 2 cores -> 4.1 Ghz
Turbo on 1 cores -> 4.2 Ghz
Mini-Desktop: NCASE M1 Build Log
Mini-Server: M350 Build Log
yep that's correct you can overclock with a k cpu and you can't with a non k
wrong, you can oc with a non k unit but its limited
Specs
3570 is completely locked. that extra multiplier you see is the turbo clock, Whether you turn that up or not makes 0 difference.
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
K series processors are fully unlocked, but non-k series processors are partially locked.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Half right, technically the max clock on that turbo is the single core threshold. So only goes to 3.8GHz when 1 core is in use, you can make it run at max turbo on all cores.
Even my i5-3475S which is factory 'underclocked' to 2.9 Ghz can be overclocked to 4.0 GHz on a single core (3.9 on 2 cores / 3.8 on 3 cores / 3.7 on 4 cores)
The CPU multiplier changes dinammically anyway ... while surfing LTT it stays at 1.6Ghz - 1.8Ghz.
Not that I really care ...
