Budget: 4500$
Country: Australia
Games, programs or workloads that it will be used for: Games Mostly on ultra or very high settings, also i use blender from time to time
so having a computer to work with that will be nice but i don't do big projects on there until i get better and i do editing
Other details: So my existing part list is as follows
AMD Ryzen 9 5900X $589
Corsair ICUE H150I ELITE CAPELLIX Liquid CPU Cooler $258.83
Asus ROG STRIX X570-E $455
G.Skill Trident Z 16 GB (2 x 8 GB) 3600 CL18 $148.83
Seagate IronWolf Pro 16 TB 7200RPM HDD $629
MSI SPATIUM M480 1 TB M.2 NVME SSD $220.21
EVGA RTX 3070 TI $1199
Corsair RMx 850 W 80+ Gold Fully Modular ATX Power Supply $196
Windows 10 64 bit $169
Corsair LL120 120mm Fans 3-Pack $98
Corsair LL120 120mm Fan 1-Pack $29
And for Peripherals  SteelSeries Apex Pro $269
I have a mouse and 144 hz monitor 2560x1440
https://linustechtips.com/topic/1425676-first-build-help/
The 5800X3D will give a higher framerate in gaming, and still have more than enough cores for whatever your doing in blender.
That meme motherboard will be of no benefit whatsoever, just get a normal one.
I’d also opt for a 240mm or 280mm cooler so you can mount it on the top of your case, keeping the frontal intake air cold until it hits your GPU.
Ditch the 16tb hdd, completely pointless in 2022.  Also, that SSD will game no differently than a samsung 980 and even for work stuff the difference wont be noticeable outside of pro level work.  You can get a 2tb 980 for less than that 1tb pro ssd.
Don’t pay for a windows liscense, just get one on ebay for $5.
If your hell bent on wasting money on memes, at least do yourself a favor and get a decent, supportive chair if you haven’t already.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1425676-first-build-help/#findComment-15357988
Overpriced asf, just geet the cheapest 360 you can find (sort from low to high)
Its not even good, just a meme of a board if you ask me, get a decent b550 like b550a pro instead cause basucally nothing useful (for most ppl) actually uses the extra chipset gen4 lanes like multi gen4 ssd or multi gpu
Not even decent spec and its overpriced, just get a 32gb 2x16 kit at this budget for futureproofing reasons, if you dont care about fast ram rgb pro can be had for similar to ballistix prices, if you want ludicrously fast ram (4000+ cl16 or 4500+ cl18) then go for ballistix but you need to tune them yourself, just pick between flashy semi decent ocing rgb pros or ludicrous speed ballistix
Thats just excessive for gaming
No use for gen4, just get a decent 2tb gen3 like cs2130/3030, silicon power a80, kingston kc2500, etc.
Get a 3080(ti)
Msi mpg 850w is 110$
Not bad considering its aud but still overpriced, if you dont care about lighting zones then nust get cheaper rgb fans. Though better off with just buying a decent mesh case with rgb fans preinstalled
W10 pro is ~20$ from cheapkeys sites like scdkeys/kinguin, ebay does sell for cheaper though apparently some are random keys so depends if you wanna take the risk (though theyre dirt cheap)
https://linustechtips.com/topic/1425676-first-build-help/#findComment-15358071
Not even a risk, I did my dad's like 4 years ago and it's still good.  I've yet to hear from some one of it getting revoked.
https://linustechtips.com/topic/1425676-first-build-help/#findComment-15358084
4 minutes ago, Somerandomtechyboi said:
So they dont sell random keys and its guaranteed key now?
It follows a pattern.  Someone uses their org's volume keygen inappropriately and sells the offspring.  Someone would have to snitch HARD for microsoft to care, and existing offspring would likely be let be.  At least that's how the ebay ones are.
https://linustechtips.com/topic/1425676-first-build-help/#findComment-15358118
