Hey guys!
I live in Hungary. It is a bit more expensive then in the U.S. This is the site i am normally using: https://www.pcx.hu/
The aim is gaming and autocad, mathcad use.
So i was wondering witch build is better?
 http://pcpartpicker.com/p/3vDQ0 and add a dedicated video card later? Like an r9 270 or gtx 750ti.
or
http://pcpartpicker.com/p/3vDV0 this is a bit more but in hungary they are the same price.
In Forints (HUF) i have 135000.
Thanks for the help.
Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU
Alcatel OneTouch D5... IT WORKS!!
http://pcpartpicker.com/p/BxMjTW
https://linustechtips.com/topic/142520-witch-build-for-500/
intel one, the 4440 packs a punch and if you can get a 500w (or so) psu you should be set to add anything
Specs
https://linustechtips.com/topic/142520-witch-build-for-500/#findComment-1902369
I'm no grammar nazi but I feel that it's time to once and for all make everyone who writes "witch" instead of "which" understand the differences.
Witch - A fictional character in cartoons and movies like "The Wizard Of Oz".
Which - Asking for information, usually involving several choices from an infinite set of choices.
---------- An example would be as follows: Which computer should I get, the Mac or Windows PC?
That should now clear up how different those two words are.
With understanding that now, I don't think you want a "Witch PC" @Abel225. :P
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/142520-witch-build-for-500/#findComment-1902414
i am terribly sorry. I know i just didn't pay attention. uhm and i like witches... Especially from Magi... Hehe..
https://linustechtips.com/topic/142520-witch-build-for-500/#findComment-1902456
I would go with a wizard build since were boys and all.
Nah witches for the win...
https://linustechtips.com/topic/142520-witch-build-for-500/#findComment-1902459
Not to worry mate! But at least now you know for next time. :D
https://linustechtips.com/topic/142520-witch-build-for-500/#findComment-1902474
next time i will pay attention...
https://linustechtips.com/topic/142520-witch-build-for-500/#findComment-1902499
I'm straight
this is your avatar:
photo-thumb-41665.png?_r=1397453852
that is all.
Failed to see a man yet
some of us are men
please stop this. You van have an argument privately...
https://linustechtips.com/topic/142520-witch-build-for-500/#findComment-1902504
Good on ya! :D
https://linustechtips.com/topic/142520-witch-build-for-500/#findComment-1902561
