RTX 3080 at idle has temps at 60 degrees C
1 hour ago, Alex Atkin UK said:Have you checked what clock rate its idling at? I wonder if its not going as low as it was before.
I notice my PCs idle power consumption had rocketed recently and thanks to your post I discovered my 3080 is idling at 1710Mhz and checking earlier posts on this forum, this would cause it. I Googled and saw mention that G-SYNC can cause this and I recently upgraded my TV, but turning off G-SYNC doesn't fix it for me. Although its still idling at 45C in a 21C room, that idle power consumption is a BIG deal as its about 120W more than usual, that's enough to power my entire NAS.
I also tried changing Power management mode back to Normal from Prefer Maximum Performance, didn't do anything either.
There is also mention that RTX Voice / Broadcast running will do this as it keeps the Tensor cores constantly active even when not in use, but I don't have that installed.
So I'm with you trying to figure this out.
Found the answer. Thanks for the heads up on checking clock rate at idle. I ran DDU in safemode and reinstalled the drivers. It fixed the issue. Apparently this is an on-going issue with nVidia and some people bypass the issue with installing studio driver instead of the game ready driver. The bug causes your GPU to clock at 1750mhz and memory clock at 9550 mhz at idle. I would address this issue as soon as you can so it doesn't kill your graphics card.
29 degrees C at idle for GPU.
