changing firmware?, help
Solved by Levent,
11 minutes ago, Nuh_ said:I want to install RouterOS on it. if that's even possible
You cant, atleast not without spending few thousand hours porting and reverse engineering. Check DDWRT,Freshtomato or OpenWRT and see if they have a build for that device, if not first part of my answer applies.
EDIT:Modem/router combo devices are almost never supported by third party firmware.
