weird laptop power problem
Go to solution Solved by KingTdiGGiTTy,
Your battery is probably worn out
ok si whenever i shut my laptop down, its usually at about 100%. however, today, when i start up again, it shows that the batter is not charged at all. also, after startup, it immediately shuts down again and i have to manually power on the computer again. no clue what is going on
https://linustechtips.com/topic/1424632-weird-laptop-power-problem/
