Having issues with my mice
Solved by 191x7,
8 hours ago, OnionRings said:@191x7
Alright I've tested it out on my brother in laws PC and its still happening, so it has to be the mouse then, but it happened on my past 2 mice as well, what on earth? Are all 3 of them just junk garbage? I don't know. I can't afford a new mouse right now, so I just deal with it I guess. I did use some canned air under the mouse buttons so ill see if that does do anything, but I can't imagine there anything in there, the gap is so small.
You can open the mice, open the switch and straighten the spring.
Or, if you can solder, you can replace the switches.
It's a common thing to happen, usually with the left because those are used a lot more.
