Watercooler for Coolermaster NR200P case and ASRock Z690M-ITX motherboard
1. Using an AIO in the NR200P with the tempered glass panel is not the best option. If you use the mesh panel, side-mounting an AIO is fine, custom Loop is a bit of work and requires specific parts, but awesome.
2. EK-AIO Basic 240 (D-RGB 240) is your best option (with maybe a fan swap, if you find the fans too noisy after a while)
3. You can order/get EK for cheap, as the company is from your country, Slovenia (so probably cheap/or free shipping often, and fast delivery)
4. Lian Li Gallahad 240 is a good option as well (V2 ,or SL V2, though the SL is more than 150 eur)
5. That Asrock board was hard-locked the last I checked and you won't get much out of the 12700K in it.
6. That Asrock is the best designed board for small-form-factor+power hungry M.2 due to being the only one to have both NVMe drives at the front side.
7. The board has the best compatibility for Air cooling (out of all the LGA 1700 boards), It's also very compatible for custom Loop with combo pump+blocks for Small Form Factor cases
8. Air cooling works good in the NR200P (<155mm heigh with glass panel, and <158mm height with mesh panel) enabling use of the top coolers available in the market.
9. Thermalright Peerless Assassin 120 SE, Scythe Fuma 2, Noctua NH-D12L, will be close to the 240 AIOs.
10. There's detailed guides below, from the guy who did the most extensive reviews and testing on the NR200P the earliest (The guy from the previous video though, summarized the points very nicely). https://www.youtube.com/c/MachinesMore/videos Optimum tech also has many videos about liquid cooling in the NR200P https://www.youtube.com/c/OptimumTech/videos The Optimum videos are especially good, cause there's guides for bigger liquid cooling in the NR200P.
A comparison of the all the air and liquid coolers I mentioned:
