Journal: hunting down and trying to fix USB electrical noise in an audio path.
Did absolutely nothing. No change in the noise in dB or subjective profile.
-20dB change in the noise floor. -70dB is mostly inaudible without having the gain cranked to absurdly loud levels. The sound profile is still buzz-y (maybe 60Hz hum?) but it lost a lot of the "data" fluctuation sounds and is a lot more consistent.
Basically completely fixes the noise. I can split hairs and say that -84dB isn't complete silence but I barely hear it with the gain maxed out and have to have my ear next to the speaker.
With a Monoprice USB power adapter providing external power (there's a switch on it to change internal vs. external power)...no difference it is still -84dB.
This only does anything when it has external power, it changes the hum to a slightly higher pitch than the "Compact Hum Eliminator" and similarly filters out the data fluctuation sounds. This thing cost like $60 though sooooo.....nope.
OK what if you completely change to a different USB interface? Well...exact same noise outcome of -50dB, same sound profile.
Conclusion:
Nobsound really won this thing. I don't what it's doing but whatever it is by far worked the best at cleaning up the sound. And for only $25 which is cheap compared to a lot of the other "solutions". I'm not going to sit here and say it'll fix every audio issue because god only knows how many things can create noise in an audio path, but at least from what I observe it really cleaned up USB based noise.
