Need recommendation between 2 monitors
Hey guys! So Ive been reading a lot of subreddits and websites and I have narrowed my search down to two monitors for my budget - Xiaomi Mi Curved Display 34 and LG 34WP65C-B. Monitor will mostly be used for non fast paced games like wow and some arpgs. So ghosting should not be an issue. Which of the two would you guys recommend?
https://linustechtips.com/topic/1423073-need-recommendation-between-2-monitors/
Both have similar specs, so check out the warranty coverage, usually xiaomi product are privately imported so only 1 year warranty.
But for the build quality i prefer xiaomi, the stand is very well made.
Yes very close call, both have VA panels and are close, seems the Xiaomi has better color coverage...
https://www.bhphotovideo.com/c/product/1662545-REG/gigabyte_g34wqc_a_34_4k_144hz_va.html/?ap=y&ap=y&smp=y&smp=y&lsft=BI%3A514&gclid=EAIaIQobChMI18GW8eH_9gIVSWxvBB1CnglXEAQYASABEgJvbvD_BwE
on sale for 299
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
Xiaomi actually make pretty solid products, contrary to what some people believe.
That said, LG products do last a very long time.  Based on personal experiance alone I would go for the LG monitor.
The panel specifications are so similar, I bet Xiaomi are using the same one LG is.
16 hours ago, Ryan829 said:
I live in Europe, so shipping alone would cost me almost 100usd. Thanks for the tip tho 😄
