Hi everyone, I'm kind of stuck choosing a new headset for gaming. It's important for the headset to not "hang" on your ears as I have a pretty slim head. Not all headsets may be available for me, but as far as I've seen these are a couple of contenders:
  • Logitech G Pro
  • Acrtis 1
  • Xbox Stereo
I could've added Cloud Stinger to the list, but it looks really "cheap" for me. Design is important too since I like everything minimalistic (well all of the above are pretty slick)
Price range should be similar for all of those, but certainly not higher than G Pro. Thanks a lot!
https://linustechtips.com/topic/1423068-help-choose-headset/
All three of those suck, it's hard to recommend anything in that pricerange let alone a "gaming" headset. The Cooler Master MH751/MH752's however are based on the Takstar Pro 82's, which are pretty much the go to closed-back for under ~$100. They commonly retail for about $80 USD, and those would be the recommendation.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
https://linustechtips.com/topic/1423068-help-choose-headset/#findComment-15340018
I would either recommend saving up a bit and getting pc38x or getting something like the k371 (which fits in your budget but doesn't have a mic [also non bluetooth version]) and a seperate mic.
If you manage to find a beyer tygr 300r it's basically the best one for anywhere near the price range.
https://linustechtips.com/topic/1423068-help-choose-headset/#findComment-15340317
Thanks @OfficialTechSpace, @Einoo for your replies. The thing is that you can't find all of those models where I'm at. Main ptions are mainstream brands like Hyper, SS, Razer, Logitech. The only one is k371 and it costs 140$, which is a lot here. I have an option of grabbing G Pro X for the price of regular ones (around a 100$), so may be I'll go with these ones. I'm a pretty casual gamer and I won't use this headset for music since I have major 4 as a daily driver.
Do you still think I should avoid G Pro's or SteelSeries headsets? Like there's not much choice here, but I still want to get a least best from what's offered
https://linustechtips.com/topic/1423068-help-choose-headset/#findComment-15340666
Ok first of all k371/k361 shouldn't cost anywhere near that much. From my experience using arctis 1, 7 and 9x they have all been among the worst headphones I have tried even beaten by 5€ supermarket earbuds. I have not tried the G Pro X but I haven't heard anything positive about it. You could check if the new rode nth-100 is available. I just got mine and it honestly beats most closed back headphones under 400€ for around 150€ . I would either recommend just saving up or getting some moondrop quarks or something.
https://linustechtips.com/topic/1423068-help-choose-headset/#findComment-15345675
