Need Help on PC build
By
RKC
in Troubleshooting
in Troubleshooting
Solved by RKC,
51 minutes ago, 191x7 said:My bad, i totally skipped the part about swapping cables.
Is the drive on the SSD support list?
Ahhh, I think I see the problem now.
The 1tb is not supported and only the 250gb.
Thank you.
PopsicleHustler ·
Posted in Audio2 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory11 -
11
play_circle_filled
Latest From ShortCircuit:
