OKAY, so i built my pc, the build is a Asus tuf b550m pro wifi motherboard, ryzen 5 5600x, GTX 1660super, Corsair 750 power supply, Corsair 2x8 vengeance ram, build in a 280x corsair case. So i built it made sure everything was plugged in, plugged the hdmi cable into my monitor and turned it on... and there was bassically nothing, no fans spinning, ram rgb didnt light up, the only thing that did kinda "Work" was the rgb on the bottom right of my motherboard. So then like anyone i started panic googling, and i found out that it needs its bios flashed, so i downloaded the bios update to a USB stick, and plopped it into the bios usb slot, and clicked the bios flash button. the light blinked for around 3 mins then went out. i removed the usb stick and turned the pc off and back on and NOTHING, i tried the same thing 3 times and nothing happened, im really stumped rn, this is my first pc build but i spent MONTHS researching and this is what happened. Im just really lost rn any advice would be gladly appreciated. Thanks-
https://linustechtips.com/topic/1422009-help/
Sounds like your front panel headers aren't plugged in right
Even if the BIOS version was incompatible with your cpu, it would still soft-boot with fans spinning, LED's and such.
I've also hidden your other post. Please only post once.
https://linustechtips.com/topic/1422009-help/#findComment-15332219
