solution to cool down R9 390
frozensun
Hi friends.
Yesterday while gaming card reached 85 °C.
Maybe it is not too much for a R9 390,but my obsessive thoughts are stronger, to try to cool down this "heater".
This is a triple fan card.
I want to try to cool it for at least 5°C.
I have managed to do the same trick with 2080 Super though it's other case.
So I added one Sickleflow fan at the bottom which reduced the temp by only 2°C (83° C max).
I have disconnected it because it is 3-pin fan and it runs at max speed,and is very very loud.
I've installed fan to blow air towards GPU,maybe I should try opposite?
So I don't have 4-pin fans here,I have 2 more of these Sharkoon fans (same ones I got with the case),and I have a pack 3in1 of Sickleflow ARGB fans (link below).
Sharkoon fans:
https://en.sharkoon.com/product/26876#specs
The case is Sharkoon Nightshark RGB, as you can see the intake room for front fans is covered be this mesh.
In my opinion these fans are average.
Same fan is set as exhaust.
So I thought to try to add 2 more fans at the bottom of the case,but dunno should I set them as intake or exhaust?
I'm also thinking about replacing all 3 fans which came with the case and put 3 of ARGB Sickleflow fans.
Sickleflow fans:
https://www.coolermaster.com/catalog/coolers/case-fan/sickleflow-120-argb-3in1/
But then again as you can see the design of the case is so bad,not much room for fresh air to take (covered with mesh-pic below),so I'm not so sure if I will get improvements on it.
All my other fans I have in stock are 140mm and they don't fit in this case.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
How about cleaning everything and repasting the card?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Too much work...besides card hasn't been used much at all,cuz I wanted to sell it.
update:
Added one more fan to the bottom,reduced temp to only 82 C so it ain't worth it.
I guess this GPU is designed to work under these conditions, and that is about it.
update:
My 2060 Dell G5 Edition runs at 85 degrees with ease if I don't limit its power or turn on my externally powered internal 2nd fan that was originally in the back but now sits loosely in the front now
Okay so I opened the side panel with Sickleflow fan at the bottom,steady 80°C.
Your whole system is dusty.
I've cleaned it already.
