HELP 1 Drive In To Two
Solved by FizzyFantom,
You can do it from the Disk Management window. You will need to delete the E: partition (you will loose all the data on the partition), then you can extend the C: partition using the now unformatted space, making the C: partition 445GB.
Featured Topics
RoyTheGeek ·
Posted in Phones and Tablets0 -
NexDeformedpoto ·
Posted in Networking1 -
3
6
2
Soapy1234 ·
Posted in CPUs, Motherboards, and Memory2 -
tridy ·
Posted in Programs, Apps and Websites2 -
Gabrielzv1233x2 ·
Posted in Troubleshooting4 -
3
RiftenGuard2011 ·
Posted in PC Gaming4
