AIO pump tubing orientation
Solved by Crunchy Dragon,
Unless you care about the text being upside down, it should function just fine if the tubes are on the left side.
As for repasting, it's probably recommended, but if you're just taking the pump off for a few seconds to rotate it, I don't think it'll matter too much.
Featured Topics
Tom1200 ·
Posted in Troubleshooting1 -
4
zekebloke ·
Posted in Programs, Apps and Websites3 -
3
uncanny_mac ·
Posted in Troubleshooting6 -
Nyu535 ·
Posted in Troubleshooting5 -
8
