How do I remove the fan from my cooler?
CreateSean
I"m upgrading my cpu and thus need to remove the cooler, but it appears that I first need to remove the fan from the coolling fins. I've tried pulling the metal clips on the site, but it feels like they are going to break.
Cooler is Noctua NH-U9S
Is there a better way?
You need to pull the metal clip backwards slightly and then outwards, it's designed to have a bit of mounting pressure.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
