Same Radiator Fans?
Go to solution Solved by WoodenMarker,
Yeah I have been using this config for a while but I was just wondering if it will affect either fan's lifespan as they have probably different static pressures.
Unless the static pressure can rip a hole through some sheets of cardboard, probably not.
On my Zalman LQ310, it came with a PWM fan and I attached a Cougar Turbine (3pin) on it also to do a push pull configuration. I was just wondering if it is required to use the same fans (I have another Cougar Turbine lying around) or does it not matter?
Zalman Fan:
Speed 900 - 2,000rpm ± 10%
Bearing Long life bearing
Control Method PWM Control, Auto Restart
Connector 4Pin
PWM Duty Cycle 30 - 100 ± 5%
Cougar Turbine:
Speed
1200
Air flow @ 12V (CFM, m3/h)
60.4 / 102.6
Air pressure @ 12V (mm H2O)
1.73
Noise
17.7dB
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/142023-same-radiator-fans/
I don't think it does.
https://linustechtips.com/topic/142023-same-radiator-fans/#findComment-1895925
I'm pretty sure fans are standardized in some way, so you should be fine.
- "some salty pretzel bun fanboy" ~ @helping, 2014
- "Oh shit, watch out guys, we got a hopscotch bassass here..." ~ @vinyldash303
- "Yes the 8990 is more fater than the 4820K and as you can see this specific Video card comes with 6GB" ~ Alienware 2014
https://linustechtips.com/topic/142023-same-radiator-fans/#findComment-1895938
I don't think it should be a big deal.
But keep in mind I have a thug of a Noctua sitting on my shelf that so far has a kill count of 3 CM fans.
I doubt you'll have any problems, just putting that out there.
https://linustechtips.com/topic/142023-same-radiator-fans/#findComment-1895948
https://linustechtips.com/topic/142023-same-radiator-fans/#findComment-1895991
Oh alright lol thanks for your reply. :)
https://linustechtips.com/topic/142023-same-radiator-fans/#findComment-1896075
