Hi All,
I am a twitch streamer and back in September of 2021, I built a new PC since the Motherboard on my old build died on me. I decided to go all new parts with the exception of the GPU (for obvious reason) and the Power Supply.
Since using this build, whenever I try to Stream a PC game, after about 30 min, both my monitors will flash black for 5 seconds, come back, apps will crash except the game and OBS, the sound with start to have static in it, and my stream will have MAJOR buffering. Upon inspection in OBS, I see that "skipped frames due to encoding lag" goes off the charts. and after quitting the game, it all goes back to normal. I Checked my GPU drivers (all up to date) and lowered game visuals to get the same results. I ran Furmark for 12 min while not streaming with no stutters or crashes Max temp hit 85C. This issue does not occur when using my internal capture card and console. Any thoughts on this?
Specs: Ryzen 7 5800x, Asus ROG Strix B450-F Gaming II, G.Skill Ripjaw V Series 16GB (2x8GB), Asus GTX 1080 (from 2016), EVGA 450 W Power Supply (80+Bronze) (from 2016).
Could this be a GPU issue? Or maybe a power supply issue?
https://linustechtips.com/topic/1419970-streaminggaming-on-the-same-pc-issues/
Windows 11?
Windows 10 with fTPM and secure boot?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Welcome to the forums!
Seems like a GPU caused issue, make sure it's seated firmly in the slot, PSU connectors are fully plugged in etc.
Then run DDU in Safe Mode to fully purge/reinstall your drivers.
Did you reinstall Windows on the new board? I recommend doing so if not.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
Hi! Yes, this is a fresh windows install from when I built the PC (new NVMe Drive). I removed the GPU, dusted it to hell, and reseated along with the cables. Same issue
I can try to run DDU in safe mode. Hopefully that helps
That's because of your internet connection.
Do a speed test and share the results:
https://www.speedtest.net/
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
It's due to encoding, not internet speed. I had buffering issues from my internet before so I upgraded to gigabit. Haven't had buffering issues due to internet since. See attached results
I know it's System based due to this being what freaks out in OBS (see attached x2)
Are you using NVENC?
Did you try streaming with Nvidia's ShadowPlay?
2 minutes ago, Bad5ector said:
Do you happen to know how much wattage you are pulling when doing all that? That 450watt PSU might be struggling.
What did you upgrade from?
So the PSU is the same from my old build (like the GPU). which makes me also think it could be the problem. BUT it does take a while before the issue happens (30 min or so).
No clue how much wattage im pulling.
I upgraded from an i7 6700k CPU though if that helps with where I came from
I think HWinfo can give you rough idea. But yeah I would try putting in at least a 550 or greater. If it were me, I'd shoot for the largest I could afford... just incase you find a shiny new video card, that will most definitely require more juice than your 450 watt can provide.
I've been considering grabbing a 1000W anyways, because I do plan on getting a 3070 or 3080 at some point! Im hoping this does fix the greater issue
1 hour ago, beardedblake12 said:
Windows 11. Sorry I forgot to mention
This is it:
https://www.tomshardware.com/news/amd-issues-fix-and-workaround-for-ftpm-stuttering-issues
You can wait for the next major BIOS update or you can install Windows 10 and not use fTPM.
