My ethernet connection to the mobile router is faulty somehow. Every now and then (often), the network shuts down and I have to wait 10-20s till it's up again.
I'd prefer having the cable over wifi if it worked.
So today I got tired of it and activated Wifi without deactivating Ethernet.
Do you guys know how my computer handles it ? does it use ethernet, wifi or both ?
Does ethernet still break down but now wifi takes other ?
It's weird, in the taskbar sometimes there's the ethernet symbol and sometimes wifi symbol
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1418921-ethernet-wifi/
Windows, by default, will use Ethernet and fall back to WiFi but you may still notice a blip since it does not stay connected to WiFi but will have to authenticate when failing over. There is a registry setting to have both active at the same time and while Windows will use Ethernet by default it won't cause a loss of traffic when it fails over with that setting enabled.
Quote
1. Open Registry Editor.
2. Go to HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WcmSvc\Local.
3. Create/change the fMinimizeConnections registry DWORD to 0.
4. Close Registry Editor and reboot.
https://answers.microsoft.com/en-us/windows/forum/all/wifi-disconnects-when-ethernet-is-plugged-in/00329022-6cad-4ea4-8a0a-ab1e38812e32
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1418921-ethernet-wifi/#findComment-15310407
But my wifi seems to stay ON too even without the hack
https://linustechtips.com/topic/1418921-ethernet-wifi/#findComment-15310416
Ah, might be something that changed in Windows 11 then or in later versions of 10. For a while you had to do that yourself.
Prior Build Log/PC:
https://linustechtips.com/topic/1418921-ethernet-wifi/#findComment-15310428
