Hello all!
I'm new here but couldn't find much on the topic so i thought i would ask for help. I tried OC my cpu but seems to crash very often so i'm sure i'm doing something wrong.
Can someone help me OC it properly? 🙂
My setup :
CPU - i5 - 9600kf
CPU Cooler - Arctic Freezer 34 eSports DUO
MB - AS ROCK Z390 Phantom Gaming 4
RAM : 2 * CORSAIR VENGEANCE LPX DIMM KIT 16GB 3000 MhzXMP 2.0 SUPPORT CMK16GX4M2B3000C15
SSD :  KINGSTON NV1 M.2-2280 PCIe NVMe 500GB
https://linustechtips.com/topic/1418753-oc-help/
16 minutes ago, NasSeKa said:
Hello all!
My setup :
CPU - i5 - 9600kf
RAM : 2 * CORSAIR VENGEANCE LPX DIMM KIT 16GB CMK16GX4M2B3000C15
OCing takes a lot of work, learning, and patience. It’s going to be very difficult to get a full rundown of how to do it without a lot more information. But I mostly suggest reading forum guides on how to OC both your CPU, and with your specific mobo (or at least a very similar mobo). Understand how you go about increasing speeds, testing, increasing voltages to make it stable, checking temps and testing stability again, rinse and repeat until it’s stable at the speeds your shooting for assuming temps are under control and voltages are safe.
Vdroop is also important to understand. A little vdroop is a good thing.
It can take a week to get a fully stable, lowest voltage possible overclock. If your PC is crashing when OCed but not at stock speeds. It likely is your OC settings, either too much GHz, not enough voltage, or to high temps (or all three, or only 2 of the 3). Also VCCIO or system agent voltages may need some tweaking. OR your CPU can’t run at your rams XMP speeds with a high core clock, which would require VCCIO or system agent tweaks if even possible. What speed is your RAM? Is XMP set?
OCing these days can be easy, YouTube videos certainly make it look easy. But there is a lot more to it…. And it takes a while to fully master. Take the time to read through guides and watch videos specific to your CPU and mobo. I have been OCing for over 15 years, and when I get a new platform (like when I went from a 9900k to a 10700k) I spent about a week reading forum guides and watching videos learning the nuances and changes even just from 9900k to 10700k….
https://linustechtips.com/topic/1418753-oc-help/#findComment-15308998
Thank you for the answer, it's 3000Mhz, XMP 2.0 supported. Yesterday I downgraded to 4.7 on CPU and RAM to 2800 and seems to run kinda stable(Still didn't crash xD) but sometimes i get some freezes on the screen and i couldn't say I overloaded it too much at that time tbh.
https://linustechtips.com/topic/1418753-oc-help/#findComment-15309022
If you are unsure about what settings you might have applied or what exactly crashes your PC, I'd suggest clearing CMOS, enabling XMP, and then start again with experiementing with OCing your CPU, so you're back to "basics" and have a clear understanding on what exactly is crashing your system.
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1418753-oc-help/#findComment-15309026
It doesn’t necessarily take a heavy load to make it crash. If voltages are not correct and vdroop is not enough, transient loads can cause crashing. There is a lot to overclocking….
I would reset defaults, apply XMP, and try and learn a lot more about overclocking and what settings need adjusting. 3000mhz is pretty easy for CPU’s to run, so it likely is fine at 3000mhz. Just need to dial in the CPU OC and voltages to get it stable. And make sure you stress test with something like AIDA64 for at least 10 hours is my recommendation.
https://linustechtips.com/topic/1418753-oc-help/#findComment-15309046
