Spec:
Carbon x570 motherboard
Ryzen 7 3700x
32 gig crucial ballistix ram
Evga 850 watts bronz
Darkflash phantom atx mid tower
Evga 1070 gpu
Problem: pc wont power on
I'm trying to troubleshoot a problem with my cousins pc. Apparently his gpu started smoking and now the pc wont power on. Theres a solid red light at the top left side of the motherboard so I'm assuming there's power going to the pc bit when pressing the power button, nothing happens. Would this mean there's something wrong with the motherboard?
And yes I know the pc is dirty I'm equally as disgusted.
https://linustechtips.com/topic/1418749-pc-wont-power-up/
Clean it. Or make the cousin do it with cotton swabs, tweezers and a toothbrush. That way the cousin will learn the importance of keeping the PC clean.
On the picture, there's no GPU. 3700X doesn't have integrated graphics so you can't boot without a GPU inside.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1418749-pc-wont-power-up/#findComment-15308927
10 minutes ago, Sighhhhh said:
Spec:
Ryzen 7 3700x
Evga 1070 gpu
So does it even not power on when there isn't a GPU in it?
https://linustechtips.com/topic/1418749-pc-wont-power-up/#findComment-15308930
36 minutes ago, Sighhhhh said:
Spec:
Ryzen 7 3700x
Evga 1070 gpu
From the looks of it, all that dust might have shorted the GPU. Dust absorb moisture from the air.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1418749-pc-wont-power-up/#findComment-15308955
I get the dust issue. The gpu is done, that's not a question. The problem now is that the pc wont even power on. I shouldn't need a gpu just to power on the case and motherboard. I was wondering if anyone knew about the red light indicator if maybe there may be another internal issue such as the motherboard or maybe the buttons on the case may be fried itself.
https://linustechtips.com/topic/1418749-pc-wont-power-up/#findComment-15308960
50 minutes ago, Stephen7 said:
that dust did not short anything.  an airblower could break the fans though.
in case you go with a new motherboard and cpu (with integrated graphics), it will probably come with a dead cmos battery.  a new cmos battery is probably a good idea. a dead cmos battery will lead to no post.
Screenshot_2022-03-19-09-25-13-090_com.android.chrome.thumb.jpg.43b74763834a351edae0ab27363f71f7.jpg
https://linustechtips.com/topic/1418749-pc-wont-power-up/#findComment-15312013
