SG13 fan help
Go to solution Solved by danalog,
3 minutes ago, splootbloot said:
I'm cooling a Ryzen 5 5600x with an estimated wattage of 65w. The GPU is an XFX RX 570 and, from my experience, is pretty decent at maintaining temperature with 2 80mm fans in a large case. I'm pretty sure the 140 should do me fine, as I'm already using Noctua CPU cooler.  And yes, I am using the mesh one.
Thank you again!! I'll be switching out the 120 in my list for a 140!
OK you will definitely want a 140. Also recommendation for if you buy a new GPU, get a blower card. Those work best in that case since they exhaust all heat straight out the back, instead of dumping it into the case and since there are no exhaust fans it really has nowhere to go.
Now IF your CPU fan is good enough to suck in air from the sides you could have that front 140 as exhaust, remove the dust filter in the front under the mesh (there's another dust filter behind the mesh) and that might work better.
I've been planning out a Mini-ITX build for a few weeks now and got suggested the very nice SilverStone SG13 v2. It's a nice and cheap case, and alot of people vouch for it's simplicity. I only have one issue. It calls for only ONE 120mm-140mm case fan. I don't see any other fans listed on the spec list, so is this all it would need?
I've never built a Mini-ITX, so this could very well be a common theme among these cases.
https://www.silverstonetek.com/product.php?pid=536#fgo-spec <--- here's the case and it's specs
Thanks!
( I N S E R T  S I G N A T U R E  H E R E )
https://linustechtips.com/topic/1418742-sg13-fan-help/
Recently built in this case.
The front can fit one 120/140 fan (or AIO radiator) and that's the only fan mount.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1418742-sg13-fan-help/#findComment-15308860
one more question. What kind of fan would better suit the case? 120mm or 140mm? I don't want to get one and have it turn out that the bigger one was the better option
https://linustechtips.com/topic/1418742-sg13-fan-help/#findComment-15310425
I mean there are a lot of different fans that move lots of different amounts of air... typically 140mm will be a bit quieter, higher overall airflow but less concentrated in 1 area. Just a 20mm difference between the two will make almost no actual difference.
What are you cooling? If it's a 45w chip or above and/or you're using a discrete GPU I recommend 140.  Anything under 20w you can get away with no front fan at all just CPU heatsink, it's a well ventilated case. I assume you have the mesh front one?
Works Cited
https://linustechtips.com/topic/1418742-sg13-fan-help/#findComment-15310440
https://linustechtips.com/topic/1418742-sg13-fan-help/#findComment-15310491
Works Cited
https://linustechtips.com/topic/1418742-sg13-fan-help/#findComment-15310496
