Need advice for first PC build.
Solved by Marhier,
I just put your spec in PC Park Picker, but added an RTX 3060 Ti and it came to under $2,000.00
Add a Quest 2 in there and you've got on, or just under your budget, providing you can get them parts at those prices.
https://pcpartpicker.com/user/Marhier/saved/#view=RCmDjX
There's a bit you could do to save some money there though.
You could go for a Ryzen 5600X processor, which will take off about $100.00
You don't have to go for a 970 Evo for the NVMe.
This is based on that you can get the parts at the prices listed and if they're in stock.
I'm in the UK, so bit harder for me to say, but where I am, stock is showing in most retaliers now of all these parts.
