Brocade icx 6430 issues
stpaul
How do i fix this issue. Ethernet 1 blinks 1 then turns off then i get this error message
Either fix whatever is causing BPDUs (the tiny packets that are used for STP and loop detection) to enter the switch from that cable (meaning, disable STP or similar from the device at the other end), or disable the BPDU Guard on that port. BPDU Guard is how you tell the switch "this port should only ever have endpoint devices, it will never have another switch connected to it". It is considered a security or idiot-protection feature, to prevent a dumb or malicious person from connecting a switch or similar device to a network port. For example, many companies have a policy that users are not allowed to install switches or routers at their desk.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
You need to turn off BDPU guard off on that port.
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
