1 minute ago, Cheeto3778 said:
about $200 US
Used or new?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1416363-gpu-help/#findComment-15292232
Just now, Cheeto3778 said:
Preferably new but willing to buy used
At that budget used might be the best option.
These are your best used options if you have a good enough power supply for any of the these GPUs:
GTX 970 - 500w PSU recommended
GTX 980 - 500W PSU recommended
GTX 1060 6GB - 400W PSU recommended
RX 570 4GB
RX 580 4GB 450W PSU recommended
Can they handle VR? Maybe.
System specs below
PSU: Corsair CX650M
https://linustechtips.com/topic/1416363-gpu-help/#findComment-15292256
