ethernet not working, but wifi works. HELP PLEASE
ayeeone
Randomly out of nowhere, ethernet connection stops working. I unplug and even installed a different pcie card and still nothing. Its not the cable. The port is lighting up green. I've changed the speed to 1gb. Enabled and disabled it. install and uninstalled it. updated drivers manually. Did a network reset. TCP stack reset AND STILL NOTHING! i've out of options and dont know what else to do.
Wifi works though 🙂
someone pleaseeeeeeee help me fix this issue PLEASEEEE. im losing my mind.
you did everything I was going to suggest. Are you using windows firewall? Maybe one of the profiles is set to block only ethernet????????? Turn off windows filtering platform and see if that works. If not, change cables, switch to different port on router. Are you getting activity lights?
Boot a bootable Linux like Ubuntu and check if the ethernet works. If it does, then the OS is the issue.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
did all of this already too. still nothing.
12 hours ago, shanerog said:
wireshark may help
I download it and a bunch of red stuff is coming up. something about the TCP. I dont understand it, not a wireshark expert :(
On 3/2/2022 at 10:58 AM, ayeeone said:
not a wireshark expert 😞
you can screenshot it here...
but first, run command prompt and type "arp-a" it should list the arp table.
Do you see any other IPs there?
type "ipconfig" it will list your IP, mask and gateway. Try to ping gateway, like "ping 192.168.1.254" for example, just replace this ip with your own gateway. Does the gateway reply?
While at it, make sure your own IP is proper, and not APIPA
Are there activity lights? Can you ping gateway? Is wireshark is showing tcp on the ethernet or wireless? The suggestion on another os is great. You can boot ubuntu (or others) from usb without actually installing. If it works on another os...windows is toast...reinstall. Post wireshark screenshot.
