Hello,
I think my network card might be dying but I'm not 100% sure.
So basically, my pc is allergic to 5g but not 2.4g and idk why
I got my network card around June 2020 and its been working great up until the past few months . The first problems I noticed were occasional disconnects from my WIFI which would happen once a day or so. The disconnects slowly became more frequent until I couldn't complete a speed test on speedtest.net.
I would have bought a new network card already if this happened on both 5g and 2.4g, but my pc does just fine when its connected to a 2.4g signal.
So I'm wondering if its a setting on windows 11 or something that makes my pc unable to use 5g connections. I only started to notice these problems a few weeks after I installed windows 11.
pc specs just incase it might help with something:
i5-10600k
MSI MPG Z490 GAMING PLUS
MSI 3060 ti
16gb Crucial Ballistix ddr4 cl15 3000mhz memory
Thanks,
-SvenTheDragon
https://linustechtips.com/topic/1415046-possible-dying-network-card/
What network card are you using and where is it installed?
It's possible it's a driver issue with that card, or a regular hardware failure. 2.4GHz and 5GHz do require different radios so it's theoretically possible for only one to fail, though I've never heard of it before
Salt SYSTEMs:
SYSTEM-Infinity+1(Centerpiece) -- Ryzen 5600X + RX 6800 XT + Galahad 360 + 32GB + Thermaltake P3
SYSTEM-Embrace (Portable) --Ryzen 5600 + RX 5700 XT + Galahad 240 + 16GB + Hyte Revolt 3
Are you sure its your network card and not your router?  I had a similar Issue to this with my router were it would drop out daily, so I purchased a new one and put all my network gear on a UPS and have not lost internet connection ever since.  Also if you think its you network card you can always buy a USB dongle and connect that way they are very cheap and that will help you diagnose your issues.
I dont think its my router because all of my other devices work just fine but ill see if i can find a dongle. thanks!
This makes be believe is it is some kind of driver issue. I would start looking around there, download the latest from the manufacturer and install it, see if that helps.
im using an ASUS PCE-AX3000 and its installed in the bottom most slot under the gpu
I tried the drivers but it still doesnt like 5g.
yeah thats what i was thinking but i tried it and that didnt work either
