I have an GTX 1050ti (4gb), but i want to upgrade it and but i only have a budget of 200€, which is the best cpu for best performance that i could buy with that budget? And with 300€ budget? Remember that i already have an 1050ti and i dont want anything with similar specs to my current gpu or below, is that why i say upgrade.
https://linustechtips.com/topic/1414483-need-recommendation/
What motherboard and CPU do you already have? Pretty much all quad core CPU's from the last 10 years will be able to keep up with no problem.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1414483-need-recommendation/#findComment-15279996
im planning to buy those in the future, so i dont really know which im going to have currently
https://linustechtips.com/topic/1414483-need-recommendation/#findComment-15280000
There is no valuable upgrade for you within your budget, considering you need a new motherboard, RAM, GPU and CPU before you see any substantial gains.
Your first purchase should be a higher performing GPU, such as a GTX 1660 Ti. The Xeon E3 1220 should be able to see some gains with it, so you can do the platform upgrade a bit later.
Decide the CPU/platform once you have the funds available, as the market is quickly shifting to the newer DDR5 platforms within the next year.
https://linustechtips.com/topic/1414483-need-recommendation/#findComment-15280005
i want to know what makes a gpu better than other, the vram?, the mhz, the cores ??
https://linustechtips.com/topic/1414483-need-recommendation/#findComment-15280013
All have an effect on graphics performance. Generally though, all graphics cards with the same GPU will perform within a few % of each other.
You also need a powerful enough CPU to feed a GPU at X performance. That's why you can't just throw in a 3090 and get the same as anyone else.
The practical upper limit for quad core Sandy Bridge at 1080p is roughly 1060 6GB level performance.
https://linustechtips.com/topic/1414483-need-recommendation/#findComment-15280566
