to sum this up.
system was set up as raid 5(4 bay nas).
manf said new update you will need to re set  raid.
(store data else where  at the time for said update)
installed update... there was a bug in it.(typo bug)
that showed  in correctly .
showing raid 0 as 5.
1 drive is going.
am i total screw with the data now?
i be even happy to even get 30% of the data off of it.
no family photo stuff was loss thru. that back up else where.
MSI x399 sli plus  | AMD threardripper 2990wx all core 3ghz lock |Thermaltake flow ring 360 | EVGA 2080, Zotac 2080 |Gskill Ripjaws 128GB 3200 MHz | Corsair RM1200i |200tb raw | Asus tuff gaming mid tower| 10gb NIC
https://linustechtips.com/topic/1414003-raid-volume-degrading-issue/
4 hours ago, dogwitch said:
to sum this up.
1 drive is going.
So you didn't follow the advice of storing the data elsewhere even though it told you to... Good luck. Failed raid 5 is not a trivial matter to pull data from...
On 2/24/2022 at 5:24 PM, Nick7 said:
So, was it raid 0 or raid 5?
If raid 5 - you have data.
If raid 0 - depends how 'gone' it is. If it's completely gone, all data is gone. If few bad blocks, you could salvage rest of data not affected,
raid 0.
i  able to see chunk of the data.
1 drive is going. pretty much. but the other 3 are good.
24 minutes ago, Blue4130 said:
4 Drive raid0? You are a brave guy.
lol. but like i menion firmware had a typo and when choose raid 5. it pick raid 0. but did not let me know it did that.t
2 minutes ago, Blue4130 said:
You didn't notice that you had a lot of extra drive space?
i did not. the icon area that shows up on right side of screen. and my right eye bad. so i miss it.
1 hour ago, Nick7 said:
Pretty much depends on that 1 drive that is 'going' how much you may salvage.
Good luck!
true. my question any good software to use on the raid ?
