Networking help
srneko0001
Im trying to setup firewall policies on my edgerouter-4 for guest and iot vlan. help?
I want them to be completely segregated to not be able to access main lan at all.
um basically im trying to set up the rules for the vlans to make them segregated from the main network.
See if this video is helpful.
Don't worry about the exact model of EdgeRouter being used. The steps should be similar.
Still not enough info if you ask me.
It's like saying
You: "I want to get better at sports"
Me: "Okay, do you have any particular sport in mind?"
You: "Just sports in general"
You need to more narrowly define your question.
What is your current configuration?
What is the end result you want to achieve?
What have you tried so far?
Did you look at the link I posted, did it help?
Are there any other devices involved in the configuration? If so, how are they configured?
