Slow to/from USB drive connected to Netgear router.
Edward78
Why is CIFS so slow, it started out ok, got up to 20 Meg a second then started getting slower, at 8 Meg now. It is 109 Gig to transfer. Are transfers tghis big just slow to network drives because they are?
MSI Performance Gaming AMD Ryzen 1st and 2nd Gen AM4 M.2 USB 3 DDR4 HDMI Display Port Mini-ITX Motherboard (B450I Gaming Plus AC), AMD Ryzen 7 2700 4.1 GHz, TEAMGROUP T-Force Vulcan Z DDR4 16GB (2 x 8GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
what drive is it?
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
Firecuda 2 TB SSD
Routers have very little RAM and CPU power for this, so its likely it quickly filled up the limited RAM then became heavily bottlenecked.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
