So I was downloading the newest driver for my gpu and did the custom installation and after like a minute my screen when black and I thought I might have to turn my PC off and back on but now that I did that My screen has been black my keyboard and mouse leds are working my gaming laptop is still running but my monitor is still black and I can't get into safe mode
My specs:Nvdia 1650ti notebook edition
Intel i510300h
8gb ram
HOW DO I FIX,Pls
https://linustechtips.com/topic/1413133-help/
Not supposed to interrupt driver installation by shutdown, but weird that you can't get into safe mode.
Unplug power, remove battery if it is removable, hold power button for 30 seconds to discharge and reset.
Then plug power back in at try turning it back on, if no go try inserting USB with windows recovery or linux...
https://linustechtips.com/topic/1413133-help/#findComment-15271047
