Build PSU Question
Go to solution Solved by RONOTHAN##,
It should work just fine.
Country: USA
Games, programs or workloads that it will be used for: VR, Raytracing games and normal games, AI Upscaling
Other details: https://pcpartpicker.com/list/t796hk this is my current plan
I'm just wondering if the PSU in this list should work for the build around it. I already have the PSU, which is why its not too overpowered. I don't plan on any overclocking unless you consider XMP to be overclocking.
https://linustechtips.com/topic/1413104-build-psu-question/
Yep, its gonna work you have some decent overhead so thats good, and its a decent unit so it should work fine
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
https://linustechtips.com/topic/1413104-build-psu-question/#findComment-15270809
Rtx 3060 is fine with a low power psu so 550w should be more than enough
btw im pretty sure you can prob get a better gpu if you cut down on the fans and get cheaper ones like phanteks fsk cause corsair ll/ql are ludicrously overpriced
https://linustechtips.com/topic/1413104-build-psu-question/#findComment-15270817
