So I'm going about setting up an audio system for my new setup as I recently got a proper monitor, switching from a TV that had decent speakers compared to the tinny drivers present in the monitor I replaced it with. Planning was pretty straightforward until I considered that I have multiple systems I want to be able to switch between. The systems I need to account for are a PS4 Slim, a PC, and a Nintendo Switch. How would I go about getting all of these sources to output through my speakers and my Meze 99 headphones? Any help at all would be super appreciated.
https://linustechtips.com/topic/1412323-multiple-audio-sources/
You should get a preamp; these devices act as input selectors and volume controls. Depending on the model, they may have multiple outputs. Be careful though, that no preamp can drive headphones, unless clearly stated; their output(s) are high impedance, meant to carry signals to other high input impedance devices (amplifiers, headphone amplifiers, active speakers). So, in your case, you'd need a headphone amplifier as well.
DESKTOP PC - CPU-Z VALIDi5 4690K @ 4.70 GHz | 47 X 100.2 MHz | ASUS Z97 Pro Gamer | Enermax Liqmax II 240mm | EVGA GTX 1070Ti OC'd
HOME SERVER | HP ProLiant DL380 G7 | 2x Intel Xeon X5650 | 36GB DDR3 RDIMM | 5x 4TB LFF Seagate Constellation 7.2K | Curcial MX500 250GB | Ubuntu Server 20.04
https://linustechtips.com/topic/1412323-multiple-audio-sources/#findComment-15273814
This is usually achieved with an Audio/Video Receiver... What speaker system did you decide on? Might be able to find an alternative solution
https://linustechtips.com/topic/1412323-multiple-audio-sources/#findComment-15284238
