surround sound
2 hours ago, Greenbell7 said:This is the rear speaker set that I have. I could've had it bundled with the HDMI soundbar I'm looking at, but I bought the wrong soundbar.
AmazonSmile: SAMSUNG 9100S Rear Speaker Kit - Wireless (SWA-9100S, 2021 Model) : Electronics
So I'll ASSUME it will work with the sound bar you're considering (verify).
In that case it'll pretty much be "buy sound bar, plug into HDMI ARC, go." - you might need to jump through a hoop or two to pair the surrounds with the sound bar and you'll want to adjust their volume levels appropriately if it isn't done automatically.
I expect you'd be happy with it and it'd work "well enough"
Do be aware that if you don't already have speaker wire, that you'll need some for that kit.
Also be aware that speaker positioning MATTERS. This is VERY underrated.
In an ideal world you have your speakers/soundbars at close to ear level. Each speaker is pointed at your ears. And the speakers are angled in a sensible manner. Do note that the L+R speakers in the diagram are separated by some distance. Movies are made with the assumption that there IS stereo separation. It's possible that the sound bar routes a bit more of the sound to the surrounds to compensate but I'm not sure of the specifics.
https://www.dolby.com/about/support/guide/speaker-setup-guides/5.1-virtual-speakers-setup-guide/#gref
