Budget (including currency): 1800
Country: US
Games, programs or workloads that it will be used for: Valorant ,Video editing, gta, tomb raider
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Going for a white build already have the 3060 trying to have all the rgb work in icue threw together this list of parts. Any Ideas?
https://pcpartpicker.com/list/VsNHxs
https://linustechtips.com/topic/1411167-new-build-help/
Not everything will work from ICUE as far as I'm aware.
You'll need to download something like I use. SignalRGB. Evey thing controlled through that software. Game integrations (with the pro version) and customizable designs.
I use if for my keyboard, mouse, headset stand, mouse pad, fans, ram, motherboard, CPU cooler and GPU. All different branded products so trust me it syncs everything.
As fr the build itself looks great. Not a gigabyte/aorus fan in the slightest just personal preference of brands I trust more so. If you like them then by all means. It'll look good with the build color. The price you got for everything it damn good too.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1411167-new-build-help/#findComment-15256956
You have a 250GB M.2 NVME SSD for $53 and an additional 1TB SSD for $115.
That's a total 1TB and 250GB for $168.
I thing it would make more sense and give you a lot fewer headaches if you just bough a larger M.2 NVME SSD and omitted the other one.
The Samsung 970 Evo Plus is:
1TB for $127
2TB for $220
Personally I thing you should go for the 2TB version since games and raw video footage for editing takes up a lot of space.
https://linustechtips.com/topic/1411167-new-build-help/#findComment-15256961
I would go for an i7-11700K instead, and then you can get more storage for the build too. Also added another case fan for the back of the case (exhaust).
https://pcpartpicker.com/list/hXBVnt
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1411167-new-build-help/#findComment-15259897
