Need mechanical keyboard advice.
Solved by Rovineplaya,
For anyone finding this post in the future: i ended up buying HyperX Alloy Origins. It has switches made by gateron (technically "better" than outemu or kailh), bright RGB, full metal body and a detachable cable. It is a little pricey though.
If you can i recommend buying something like Tecware Spectre Pro or Pulsar Lunar Alloy mainly for the hot swappable switches, plus they are cheaper.
Featured Topics
ColossusRev ·
Posted in New Builds and Planning2 -
Trembletop ·
Posted in Graphics Cards3 -
1
R41D ·
Posted in Troubleshooting0 -
Caroline ·
Posted in Storage Devices0 -
anirudthelinuxwIzard ·
Posted in General Discussion8
play_circle_filled
Latest From GameLinked:
Are you excited for Doom: The Dark Ages? - Gamers 2 Gamers
