DisplayPort no signal when using power strip
Leglessmatt
Hi!
hoping someone can prove I’m not being stupid…others have tried and failed 😉
I have a laptop linked to a Dell 32 inch monitor via a usbc to displayport cable (usbc on laptop end).
I was receiving ‘no signal from displayport connection’ or similar recently.  Tried various laptops/cables/etc.
I think I’ve narrowed it down to the power supply to the monitor.  If the monitor is plugged into a surge strip (six gang with all plugs used) the no signal error occurs - tried plugging it directly into the wall and it seeeeems to work fine.
other sources connected to the HDMI socket on the monitor always work fine (power strip and/or directly into the wall).
can displayport ports / monitors work like this? Surely if there was not enough power then the monitor just wouldn’t turn on? I’m guessing displayport uses ‘more power’ hence its not working when hdmi sources do…or does anyone think the monitor is possibly on its way out?
cheers,
Matt
My guess would be a grounding issue, either in you power strip or wall outlet.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    MSI Optix MAG342CQR 34" UWQHD
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
i've had some terrible luck with displayport on dell displays, especially in combination with dell cables.
no explanation for this, but what ended up working for me was i disconnected the earth lead from the display's power connector, and it got MUCH more stabile.
as for the propper fix, i've had enough facepalm with dell cables that i'd rather suggest that if you're using the dell supplied DP cable, you best stop using the dell supplied DP cable...
Cheers for the ideas, will get the multimeter out and do some prodding 🙂 #sizzlesizzle
Might be time to look for another power strip maybe. 😮
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
