9 minutes ago, itisme911 said:
Look into a dark rock 4 or dark rock TF and clearance for your case
"The be quiet! Dark Rock 4 CPU Cooler may require a separately available mounting adapter to fit the Asus PRIME Z690-P WIFI D4 ATX LGA1700 Motherboard"
https://linustechtips.com/topic/1410383-cpu-cooler-for-cpu/#findComment-15251515
V
Buy the adapter or go fo Noctua NH-D15 with listed support on amazon
https://linustechtips.com/topic/1410383-cpu-cooler-for-cpu/#findComment-15251523
