Help with linux plz :(! (Thenoob)
Well, if you want to remove Windows 8, that's one thing. You wouldn't need to create an extra partition for that.
But yes, you can create a new partition and dual-boot a Linux distro with Windows 8. The easiest way to do this is to allow your linux distro (I'm assuming you want to use Ubuntu) to install the Grub boot loader in the master boot record. Windows' boot loader is usually a pain to make recognize that there is another OS that it could boot... but Grub is pretty flexible and has no problem detecting Windows.
It's generally better to have a Windows installation first, and then install Linux.
Also, whatever distribution you install should have a partition manager that allows you to manage your disk's partitions while installing... but it may be easier to create the partition you would use for Linux in Windows first. I think Windows 8 has its own drive partitioning app built in... but I'm not 100% sure on that.
So short answer... yes, to all of your questions. Though you would need to look up which distribution is easier to install on a USB if you plan to go that route. CrunchBang would probably be your best bet... though it's not as user friendly of an OS as something like Ubuntu.
