So my graphics cards idle temp has risen majorly when i first bought it i was getting around 30-40 degrees idle it now stays around 55-60 degrees Celsius during gaming it doesnt really go above 70 which im fine with as i've got the same custom fan profile set as i did when i initially got it. I checked the card for dust there was virtually none i have my side panel off at this point but i do not have any fans pointed towards the graphics card any help would be appreciated.
Edit: The card is a 560 ti 448 core with the reference cooler at stock clocks and voltage
https://linustechtips.com/topic/140983-gpu-temp-issue/
I have had the same issue with my MSI GTX 560 Ti since i updated my nvidia drivers my temps have increased by around 5 degrees which is fine for me but im confused to why this has happened.
I do run my gpu overclock with a core of 1000 Mhz and Memory clock of 2200 Mhz and my voltage at 1050 Mv so i know my temps might be different to yours but mines at 30 degrees at idle and 70 under full load.
https://linustechtips.com/topic/140983-gpu-temp-issue/#findComment-1882079
