Hey everyone, I think I need some help with upgrading my PC…
I have been building PC’s for about 6 years now, and each time I needed an upgrade I just build a new PC and sold my old one.
But… This is quite an expensive practice and I am looking to upgrade my current PC instead of building a new one.
Specs:
-CPU: AMD Ryzen 7 2700X Eight-Core Processor 3.70 GHz
-GPU: Radeon RX 5500 XT 8GB
-Ram: 2x corsair 8GB 2133MHz (16GB tot.)
-Mobo: B450 AORUS ELITE
-Storage: 1x 1TB samsung SSD, 2x WD 2TB HDD.
What part should I replace first to improve my performance? I mainly use my PC to game.
Thanks!!
https://linustechtips.com/topic/1409757-need-help-with-upgrading-my-current-pc/
Right now your bottleneck is your graphics card, if I were you I would get a better graphics card (maybe a used 2060/2060 super - due to the fact you get DLSS) and if you have the money upgrade your cpu to a 5800x
Hope my response helps 🙂
GPU MSI Gaming Ventus OC RTX 2060 CPU Intel Core i5-12600k Motherboard Gigabyte Z690 Gaming X Memory Crucial DDR5 4800 Storage Western Digital SN850 500gb | PSU Corsair RM650x (2018) | CPU cooler Corsair H150i Elite Capellix Monitor MSI  Mouse Logitech G305 White Keyboard Royal Kludge RK61 (Cherry MX Reds) | Headset Logitech G533 |
That memory is going to be a bottleneck on that CPU, you're easily losing anywhere from 5-20% FPS running at 2133mhz.
I recommend 3200mhz minimum for 2000/3000 series Ryzen and 3600mhz is optimal.
DOUBLE CHECK IN YOUR BIOS make sure you have the memory XMP profile enabled if any, 2133mhz is the default most motherboards run at when you put a build together before applying the XMP profile. You might have faster memory and not even know it!
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
Just checked my bios and you’re right! I didn’t use the correct settings so my ram has been running at 2133MHz for over 2 years now.
My ram is now at 3200MHz and I’m having a noticeable smoother experience.
Thanks!!
If you update the motherboard to the latest BIOS, you can also just upgrade the cpu to a 5600X. Make sure you get at least a decent cpu cooler as well, if you don't have one already.
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
Thanks!!
Remember to "choose solution" on my answer so other people searching for your problem find the thread 🙂
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
