Hi, I recently bought a new prebuilt pc and realized that on the initial boot up for the new day, that my CPU temperatures skyrocket, but when I restart my pc after the temps get so high the temperatuters of my CPU run normal and perfectly fine, The specs of my PC are:
Case iBUYPOWER Slate MONO MR Tempered Glass ARGB
Processor AMD Ryzen 5 5600X Processor (6X 3.7GHz/32MB L3 Cache)
Processor Cooling iBUYPOWER 120mm RGB Liquid Cooling System
Memory 16GB [8GB x 2] DDR4-3200MHz RGB
Video Card GeForce RTX 3060 - 12GB GDDR6 (VR-Ready)
Storage 500GB M.2 NVMe SSD + 1TB HDD
Motherboard B550 AC
Power Supply 600 Watt - 80 PLUS Gold Certified
I would really appriciate it if someone could help me with this, thank you.
https://linustechtips.com/topic/1409667-cpu-overheating-on-initial-startup/
@ShrimpBrimeYeh sure, so when I start it up for the first time in the day with no apps open , it starts of at 60C and keeps rizing until it safety shutdowns to prevent damage to the CPU ( I also disabled all start up apps to see if that helped but it didn't). After I restart it, the temperatures stay at a steady 30C with no apps open
Make sure to use the quote button or @ShrimpBrimeso we can see your responses
I would guess that there's a defect in the pump that causes it to not start initially, then turning the PC off and on again starts it up. You may want to check the connection to the motherboard to make sure the CPU cooler is plugged in correctly.
Primary PC:
PSU tier list
How many watts do I need?
@Fasauceome I checked the cable for my cooler thye all look plugged in properly, I dont really mind having to restart my PC, I'm just more worried that it may cause long term damage to my cpu or any other components do you think it would be fine if i just leave it or should i reach out to IBP and ask for a refund/replacement.(i bought it on Jan 23 2022 btw)
Where is the AIO plugged in? The water pump header or cpu fan header? I believe you can use either.
Cpu fan header should always have power when you push the power button, the same should hold true for the water pump header.
Maybe try and clear the cmos one good time to be sure bios doesn't have a weird fluke going on.
