list of things to do:
rebuild psu for external PSU
add custom connector with
  • 8 AWG for 12v 36 AMPS (single rail)
  • 16 AWG for -12v
  • 10 AWG for 5v
  • 10 AWG for 3V
build case? or use ml05 for Matx motherboard?
i know that an Matx motherboard isnt supposed to fit in side but hmmm its alway fun to mod
buy a gpu either a r9 270x or gtx 760
       anyone else know any high end single 8 pin gpu?
build a seperate housing for gpu? or mod it and make it fit in an old external WD hard drive
build a custom pcie x16 to smaller connector + smaller connector back to pcie x16 or cut a hole and run a standard pcie ribbon through each case
right the proposed spec of the build is using parts i already have
  • fx 6300
  • non usb 3.0 or sata 3.0, AM3+ board its an asus one (95w)  ASUS M5A78L-M
  • ocz vertex 60 gb SSD
  • pair of 500gb wd green HDD
  • GPU undecided
  • some oem hp ram x 4gb sticks
Edited by bane0of0god
https://linustechtips.com/topic/140962-project/
what do you mean by rebuild psu? O.o
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/140962-project/#findComment-1881714
