Bridge connection
Solved by Falcon1986,
5 hours ago, codyyy said:I need your help peeps.
So i have one pc connected directly to router and i was lazy to buy another cable and i just made bridge connection to my pc.
And the problem is it loses connection after rebooting pc. Problem solves itself by just re-enabling bridge connection. I tried to automatise it somehow and didn't find any instrunctions on the internet x)
I tried googling but didn't find anything...
Not understanding this clearly.
Did you try to directly connect two PCs directly with ethernet? If so, of course the connection will be lost on reboot, but you an set up static IPs. Why so complicated, though? Why not use a simple unmanaged switch to share the connection?
