No, as long as you dont hard bend/kink them, should be safe and fine.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1406947-binding-cable/#findComment-15227887
What Skiiwee29 said.
Only thing i'm going to add, Replace the elastic band with twist tie or cable tie. Elastic Bands, especialy around electronics will degrade and snap and you'll just end up wondering why all the cable sex happened anyways.
there's no safety issue, just annoying as hell
Quote
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so." - Douglas Adams
System: R9-5950x, ASUS X570-Pro, Nvidia Geforce RTX 2070s. 32GB DDR4 @ 3200mhz.
https://linustechtips.com/topic/1406947-binding-cable/#findComment-15227934
3 minutes ago, Sprawlie said:
... you'll just end up wondering why all the cable sex happened anyways.
Haha
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1406947-binding-cable/#findComment-15227940
