Upload Problems
Solved by Bombastinator,
1 hour ago, Diov said:Ah, its a Siemens but I may need to take it out of the wall to get the make/model number, doesnt have it on the front.
I'll see about getting it replaced and see if that fixes it. the breakers on a bed/bathroom circuit, as far as I'm aware those are the only rooms on this circuit.
Seimens made better stuff than homline. An electrician may be able to make your problem for away though even if it involves putting in a cheater and running another circuit.
