USB 3.2 Flash Drive has slow write speed?
Solved by Eigenvektor,
21 minutes ago, FastByte17 said:Alright. So I believe I'll have to wait this one out. Or is there a quicker alternative?
You could try compressing / combining the small files into one large file (e.g. zero compression rate should be fine, so long as you have a single large file in the end)
Featured Topics
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
1
6
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
7
2
Shane Martin ·
Posted in Displays2
